NDB and UHF Radio
KathrinaVelasco
New Member
Mar 27, 2014
Can anyone advise me whether putting the ndb transmitter and uhf radio inside one cabinet will cause interference with each other?
Sent from my iPad using Tapatalk
greetings and welcome to the forum:
you will have to give it a try and see if it picks up any interference, ac noise is a problem for LF but specifically i would think that antenna type and mounting location along with filtering would be of greater consideration as far as overloading from the uhf transmitting signal vs location of uhf transmitter.
I have never tried ndb so I can't say for sure, hopefully someone will come along and can add some more information.
best of luck, enjoy the hobby.
By "NDB", are we talking about "non-directional beacon" transmitting? Those are typically down in the hundreds of KHz - quite a lot of separation as far as UHF goes. However, it depends on how much power each transmitter is radiating and how well shielded the transmitters' cabinets and such are. Try it out and see, bearing in mind that some equipment might be pretty tightly regulated as far as installation locations.
Like Beetle I too think of "NDB" as "non-directional beacon" such as is used on the longwave bands for navigation or as markers. If that is the case I can't really see why there would be any issue with them in the same cabinet as long as the actual installation was done correctly regarding routing of wires, grounding etc.
