Need cap list for Cobra 148GTL, PC412AB (Taiwan)
ShakyMcQuiver
69
57
Here I was complaining this morning about the overly priced radios you see on Fleabay and yard sales and I had a beautiful old-school 148 dropped in my lap! Taiwan model, side-mic, white power connector. At first peek, it looks completely virgin other than an SPST switch installed on the back that I have no idea (yet) what it does. I'll figure that out soon enough.
Good news is this mystery switch is the only extra hole it has. No channel mods, the clarifier is bone stock as is the wax in the coils, so I don't think a screwdriver has touched it. Finding virgin 148's is nearly impossible these days - or at least in my area.
Radio does work, but seems a little low on the the output (with stock mic, approx. 2.8 deadkey - swing about 3.5 and about 8 on SSB). My guess it just needs a good wash and tune (and re-cap).
Anyhow...
Looking at my SAMS, it shows the PC412AA board. Do any of you 148 surgeons know if the caps are different on the PC412AB board? I did some brief searching and found a few posts about these radios and there were some mentions of a few cap changes that the SAMS didn't reflect. Also mentioned was these Taiwan models like to pop some of the caps especially after sitting. I was told this radio has been sitting for many years and with the layer of dust it had on it.. I'd say that's a good bet.
I have a few other radios to re-cap after I finish my Cobra 2k so I'll have to place another Mouser and/or Digikey order anyway. Now that I have several radios to do, it will be more cost effective to buy the caps in larger amounts.
So... up-to-date and accurate cap list anyone? Bueller? Beuulllleeer? :)
Many thanks in advance!
Reactions: walterjn
Got bored today and went through the SAMS for the 148 and came up with this list for the electrolytics. I noticed there are 7 (?) that don't have a capacitor number assigned to them. Anyone know where those go? I'll figure it out once I start re-capping. Just curious if anyone knows.
Please correct me (or update) this list. As mentioned, this information comes directly from the original SAMS. In total, I came up with 52 electrolytic capacitors (14 values):
___________________
C10 - .22uf 35v
C18 - 330uf 10v
? - 47uf 10v
C23 - .47uf 50v
C24 - 4.7uf 25v
? - .47uf 25v
C25 - .47uf 50v
C28 - .47uf 50v
C29 - .47uf 35v
? - 2.2uf 16v
C33 - 1uf 50v
C62 - 1uf 25v
C67 - 1uf 25v
C72 - 33uf 10v
? - 22uf 10v
C73 - 22uf 10v
C74 - 47uf 6.3v
? - 47uf 10v
C80 - 2.2uf 25v
C81 - 2.2uf 25v
C84 - 1000uf 10v
C90 - 2.2uf 25v
? - .47uf 10v
C92 - 4.7uf 25v
C95 - 47uf 10v
C99 - 2.2uf 25v
C100 - 22uf 6.3v
C101 - .1uf 35v
C103 - 10uf 6.3v
? - .47uf 50v
C104 - .47uf 35v
C108 - .47uf 50v
C109 - 10uf 16v
C133 - 10uf 16v
C134 - 10uf 16v
C135 - .47uf 50v
C144 - 1uf 50v
C153 - 47uf 10v
C172 - 1000uf 25v
C173 - 10uf 16v
C174 - 1uf 50v
C175 - 470uf 10v
C176 - 47uf 10v
C179 - 22uf 6v
C180 - 4.7uf 25v
C181 - 10uf 25v
C184 - .1uf 25v
C186 - 220uf 10v
C191 - 1uf 50v
C230 - .47uf 50v
C231 - .47uf 50v
C232 - 2.2uf 25v
______________________
Sounds about right. Got in the habit of buying "kits" from Klondike Mike. Pulling them from my stock takes labor. When I kept track, I found I was spending more dollars' worth of labor to pull the cap list from my stock than I would spend buying a kit from Klondike Mike. If you were to add up only the cost of the parts as we stocked them, it would be cheaper than what Mike charges. But the labor we spend to pull dozens of caps from stock is what makes his kit look cheaper at the bottom line.
I will vouch for the quality of the parts he sells. Name brands, not the one-lung-sam chinesium from fleabay.
And if you just want to obtain them all for yourself, I have one recommendation. Ignore the voltage ratings below 25 Volts. The radio has some 6.3 Volt, 10, 12 and 16 Volt rated caps. We find that the caps with the lowest voltage ratings tend to fail first. We substitute a 25-Volt part for any of them that are listed below that rating.
Besides, it simplifies the number SKUs in the inventory.
IIRC, there are some tantalum electrolytics in that list, somewhere. I tend to use the same rule for those as for the aluminum electrolytics. Minimum 25-Volt breakdown rating.
