need help. icom ic 208h has low voltage
Rwb
tell the devil im gettin there as fast as i can,r
Jun 30, 2018
4,367
6,447
523
71
in the fan line. ive installed a couple diffrent fans and all turn very slow. is there an easy way to get power back up into the plug?
if not its getting a big fan on top wired to power supply
all fans hooked to another radio turn fast move lots of air. even the original fan will move lots of air
Most fans will run slow or stop if the radio is cold, step up speed when the radio gets hotter, does the fan run slow when the radio is hot?
It runs very slow no matter the temp.it is too slow to cool it off.
It only has 2 setiings on fan.on constantly when radio is started or auto as needed. Either setting it barely moves air.
But plug same fan in on any other radio i got that uses that fan,it really moves air.
Dont know if it has hidden menu to adjust voltage to speed it up or if a part is going bad
