Need help on tube amp... ABC Electronics INC
TonyV225
Apr 18, 2005
5,824
331
143
Wisconsin
This amp needs a driver tube and the numbers are no longer visable and I dont know what it should be its a 1 driving 2 and the final tube numbers are 6JG6A it was made in Jolleit Illinois again as stated in the subject bar its made by ABC Electronics and I need the driver tube number or something that will work with these final tubes which I dont know what there rated at any help APPRECIATED!!! Thanks....Tony
Is this a mobile amp or one that runs on house current? Flip the thing over and check the voltage on pins 4 and 5 (this will be either 6.3 or 12.6 volts AC).
Let me know.
Ok its reading 7 volts on pins 4 and 5 so Im guessing its the 6KV6A because im thinking the voltage should read higher if not under a load.
The 6KV6A is a smaller version of the 6JG6A; the pins are the same.
Pins 1, 6, and 7 are (should be) tied to ground.
Pin 2 may be grounded or have a few volts NEGATIVE (this is the control grid, the bias is applied there).
Pin 3 is the cathode and this is where the input signal goes. There should be a choke from that pin to ground.
Pin 9 is the plate, there should be high voltage there; this is the output point of the tube.
If you have another 6JG6 A around plug it in there.
Reactions: Turbo T
  • @ heartbreaker3473:
