Base New install
jimmy360
Oct 29, 2021
38
4
18
50
Just installed a new patriot antenna 2 stages works very well but I’m confused on the swr my 148gtl swr meter reads 3.0 and when I test the antenna to radio with my Dosey meter in line it reads a flat 1
Try another radio with built in SWR meter
and /or another external meter in order for you to discard if it is the radio or the antenna. An antenna analyzer would be best.
Oops link to last page of thread.
Reactions: Robalo
Actually I linked to the last page not the beginning,
Is were it started.
Obviously something is not right for a 80 ohm reading.
Can you check the coax itself with your analyzer?
Can you measure the antenna at the feed point?
Is were it started.
I will do a test today I’ll put a dummyload on one end and check it with analyzer will post my results here thanks
We’ll coax is hooked up from the sark100 to the antenna and I get a reading of 80 ohms
Jimmy do you calibrate your SARK100 every time you use...it per the manual...if it has a manual?
Good luck.
Reactions: Crawdad
Used to work from the radio don’t know what happen any help would be great
There is a Tuning pot inside the radio that is adjustable so never trust the internal meter. A Dosey is not a good wattmeter but it's OK for just SWR readings.
