NOMADRADIO
avcat
Apr 27, 2005
16
West Virginia
Thanks very much for the advice on correcting the low volume
problem on my RCI 2950DX. I installed a jumper wire between
the ext. speaker and the code key solder connections on the
bottom of the circuit board and it worked fine. Those two
points gave the best results as to restoring the volume.
Avcat
Hey, cool. That was easier than it sounded. Makes me wonder if we shouldn't just jumper that part when a "DX" radio comes through here. Can't figure more than one owner out of a hundred uses "PA".
