Nordland 01 1400
TheAx
New Member
May 17, 2016
2
Hi!
I have a Nordland 01 1400 Base station. Looks much like the Kraco 2555FM. The transformer has blown. I want to put a new one in, but how much voltage and amperage is likely to be needed for a CB like this?
A 23 ch AM/FM radio . . . ?
Not much info found for it. Does it have a dual power setting for the line voltage in? Otherwise, I would guess that it steps down 120VAC to about 18-20VAC and then it would go to the voltage regulator circuit to supply 13.8VDC like most other base radios do. Have pictures of the xformer? Part # on the xformer?
Yes it is AM and FM 23 channels plus 11A channel.
No dual power output.
At the moment I'm using a 12v batteri. So I guess it shouldnt heard it to use 13.8v?
Any guess how many amps a radio like this needs maximum?
