Gentlemen where would I run the power on this radio on ssb to run a kl203 amp ssb only.
Many thanks
Bobby
Many thanks
Bobby
Ok thanks I will use it on my grant..
thanks
Bobby
Many thanks
Bobby
While I agree with what has been said you can try this. I have the 257HP and I did do this just for fun in SSB MODE ONLY once. I dialed the power down with the variable on the 257 for 12-14 watts peak, that drove my KL203 to about 150ish watts.
Doing that is far from ideal but it does work. Just be careful because if you make a mistake and leave the power up or go to AM that 203 won't last.
My 45HP is going well. Excellent audio and receive.
ive had great luck with 2 seperate magnums. curious what type of antenna did u have b4
Since changing to a Super Penetrator 500 5/8th and decent coax my signals on the transmit and receive are so much better. A friend who lives only a kilometre from me stated that he has never seen my radio peak his meter until recently which coincided with the better coax. The radio has always been good, it is so much better now. I plan to lift the antenna another 4 metres which should get my signals out further.
I guess buying a mass produced radio these days is hit and miss but I have had absolutely no problems. I have never fiddled with it and it is as supplied to me by dd018 in Indonesia. Hi Dave.
cheers
Bruce
Thanks for this. I opened up the mic , and thought, I have no idea what I am doing and then closed it up again.Back off the mic gain a little or reduce the gain of the pot in the mic to see if that helps but the addition of the CP1 compressor in the S-45 does tend to make them bassy..especially to local stations.
If experimenting with another mic use the "other" 4 pin connector.
Need to be carefull with the 5 pin as one of the pins has power to drive the electret mic insert.
