One more COBRA 2000 GTL question
Crambone
I Support WorldwideDX.com!
Jan 22, 2019
563
175
53
57
So I have a cobra that has a power mod using the TONE and goes to an empty VR10 that is working and it looks like a channel (upper / lowers ) mod using the CB/PA and NB/OFF toggles. My My Voice Lock Fine/Course has NO power going to it????? I did trace the wires and it looks like one is off but Im unsure of were it came off? Plus the frequency Counter on the radio is not working properly. Can the frequency counter issue be tied to the no power to the Voice Lock?IMG_1915.jpg IMG_1917.jpg
The loose end of the blue wire in the bottom pic should to to pin 1 of the MB3756 chip. It's pins are visible at the top-center of the pic.That would be the pin at the rearward end of the chip.
As for the frequency counter, there's a lot of room for "doesn't work properly".
Might want to be a bit more specific.
Reactions: NZ8N and Mudfoot
I will tackle the loose wire in the am and update.
Again Thank you! Maybe in 10-15yrs I will get the hang of this stuff?
  • @ Spanish:
    Where do i upload schematics
  • @ Catalyst 122:
    Who do I contact for a name change. I put in for it over a year ago and it says still under review.
