Optima mic wiring diagram (colors)
CbRadiosPRONTO
I Support WorldwideDX.com!
Mar 21, 2014
431
166
USA
www.cradiospronto.com
Does anyone know the color code for the stock mic? I have an mk3 and have been using after market microphones bid like to wire up the original.
I have the mic connections but not sure what color wires they match up to.
1 mic input - wire color?
2 +8v DC - wire color?
3 freq up/dn - wire color?
4 NC
5 PTT - wire color?
6 Ground (PTT) - wire color?
7 Ground (mic) - wire color?
8 NC
CbRadiosPRONTO
The original optima mk3 phantom powered mic is:
1. white
2. red
3. blue
4. n/c
5. yellow
6. black
7. shield
8. n/c
Pin 1 Mic Input
Pin 2 +8VDC
Pin 3 Freq up/dn
Pin 4 NC
Pin 5 PTT
Pin 6 Ground (PTT)
Pin 7 Ground (MIC)
8 NC
4 NC
5 PTT - wire color?
8 NC
CbRadiosPRONTO
2 grounds connections??usually its
ground
audio
tx
rx
then ,up,down,maybe a hot pin. im lost on this one
No audio. Hmmmm. Key up and channels work but no audio.
Well, I didn't really want to go back to the stock mic but wanted it ready to go.
I've been using a cobra BlueTooth headset that works with my cell phone and radio. Sounds as good as any mic I've ever used. Completely blown away.
CbRadiosPRONTO
ground
audio
tx
rx
nothing to be lost about,,, I posted up the exact wiring and colors used with the mk3 power mic,,
optima mk3 uses the same wiring as most icom 8 pin radios
ya i just saw it guess it worded different
mic input = audio?
ptt= tx im sure
ground ptt=???
ground mic=???
never wired a radio with 2 grounds or shields . never had a icom. only 8 pin radio
i got is my ar3500 but a mic already came wired with it..lol
Not a good idea to rely on the color of a mike wire. Manufacturers often use different colors if they run out of a particular color/gauge for whatever reason. That's when good eyes and a good continuity checker can save the day. Oh - and good notes.
    boog351 has left the room.
