HOWDY EVERYONE;
UZ7HO now has a forward error correction on his PACKET software program and it works nicely.
7101 lsb is in good condition in the evenings and a lot of packet action on 300 baud.
OK here is the setup of the forward correction.
download the program <it is free>
ON settings:
sound modem
under settings
modem settings
modem filter CHANNEL A
BPF WIDTH 500
TXBF WIDTH 500
LPF WIDTH 155
BPF TAPS 256
LPF TAPS 128
CHCK DEFAULT SETTINGS
PRE EMPHASIS FILTER NONE
CHCK KISS
NON AX25 FILTER CHCK
MODEM TYPE CH A
MODE AFSK AX25 300 BAUD
TX DELAY 250
TXT ALL 5O
ADD RX 0
AD RX SHIFT 30
BITS RECOVERY SINGLE
FX25 MODE RX+TX
PRESS OK
CHNL B
LEAVE SETUP AS IS
GOOD LUCK and see you on PACKET 7101 LSB
DOCTOR
ON settings:
sound modem
under settings
modem settings
BPF WIDTH 500
TXBF WIDTH 500
LPF WIDTH 155
BPF TAPS 256
LPF TAPS 128
CHCK KISS
MODEM TYPE CH A
TX DELAY 250
TXT ALL 5O
ADD RX 0
AD RX SHIFT 30
FX25 MODE RX+TX
PRESS OK
CHNL B
LEAVE SETUP AS IS
DOCTOR
