These are crappy screenshots but are from a Vid Bells CB offers to help you understand how to install an RFX unit.
The above
Yellow coax ID is the Inputs to the amp...
Red coax ID is the Output to the Antenna
Note the lead dress and routing
Yes, makes this radio a Negative Ground Only radio - Chassis(Case) and Foil ground bond together thru the RFX unit; - just be ready for it.
Ok, you are having problems with a Buzz...
More than likely it is from a mounting issue of the "Exciter" that generates a voltage off the back lighting using that EL panel - it is in a shielded box but it has an oscillator to make a higher running voltage so the buzz you hear, if's from this onboard clock feeding it - it's touchy so if you've moved it, relocate it (Exciter box and any wiring) back to the original spots if you can.
Now, back to the screenshots above, what Bells does, or did, is place the antenna shield to CHASSIS ground - and Foil Ground for the COAX Shield of the RF Input TO the RFX unit.
So before anyone screams that this violates a law of physics, only if you forget to read the manual...that is on you.
Wanted to let you know that Shield of the Antenna to Chassis - Shield of RF from the Final to the FOIL ground - the same ground the Final uses.
Watch the Vid here...
For Educational Purposes only
