Palomer 225 Repair Question
T23
645
12
I have a Palomer 225 and I can't figure out how I should go about opening the amp. Theres a plastic bottom... Any Ideas?
T23
something like a knife edge , stick it under the edge of the front of back about a half inch and pry the plastic up till it pops out . there's grooves in the sides that hold it in place . id suggest doing it in a place that's warm ...... just in case the plastic is the kind that will crack if its very cold when flexed .
Thanx man...Worked perfectly, I thought it slid out like my KL-60 does. but I guess I was wrong..
T23
It's a bit corroded inside, it worked perfectly last time I used it, but the power leads are too short and brittle, it looks like it has been abused quite much, I got it free with a Cobra 25 LTD classic. So no losses then...
T23
