Howdy, y'all! Just picked up the above radio with a few problems. It was totally dead when received and I found two exploded diodes on the PS board along with a 25A line fuse!!
After replacing the diodes everything seemed fine until I keyed the mic and ka-boom, diodes fragged again. I replaced them again and found the final transistor had an E-C short so I have ordered a new transistor. I de-soldered the 2SC1307 final and am able to key up without blowing diodes and in AM mode I can easily get 100% modulation on the meter.
While waiting on the transistor I figured I could at least listen to some stuff and after a while the AM signal started fading in and out like bad QSB. I can "talk" to it with my talkie and get a good swing on the meter on all channels. There is hardly any background noise when the signal fades out. Both LSB and USB sound fine.
I see in the block diagram there are separate AM and SSB AGC sections so I am leaning toward something going on there.
Any suggestions on what I should check?
73,
73,
