phillips 300 ssb cb
Now that's a rare one. What little info I could find indicates it has a uniden board inside. If you can find the board number someone here may know of another radio that uses the same board that there is info available for.
Look for something like PC-xxx, where the x's would be numbers. There may also be some letters trailing, so then it would look something like PC-385AG, for example. (Stalker IX uses that board for at least one version.)
Hi , yes it is a uniden board and the number on the board is pc-622ab , thank you for your reply.
Back again. The scanned image of the Philips 300 SSB (PC-622AB). Not the best of scans. Also need to ask my daughter if I can use her printer/scanner so I can scan the Service manual. She first has to ask the Mom (My ex). Maybe someone out there has a better quality image. Thought i would throw in the Cobra 148 GTL Alignment Points just for the sake of it. Hope someone finds it helpful.
73,
Spanish
Reactions: TM86
