Thank you. No, that LP is never going back in line. I don't even know why I had it there other than old habits. This whole mess could have been avoided by not having it at all. I will undertake the repair of the LP, but when repaired it will go back in the parts closet unless I get some complaints.Lucky for you, they still sell a MQ HG 2SC2879 16D08 set. For $128, you can repair the amp your self. Just unsolder the old transistors and pop in the same exact new ones:
Promotion-HG(HuaGao) 4 PCS 2SC2879(MQ, Match HFE) build by HG | eBay
New 2SC2879 is produced by HG China. Can replace Toshiba 2SC2879 well. We will match HFE for this 4 PCS 2SC2879. The HFE will be marked on the lids. We sincerely apologize for any inconvenience this may cause.www.ebay.com
While you are at it, get some 10ohm .5 watt carbon resistors and replace the 4 that are there.
There are higher quality LP filters out there but you can probably reuse yours by simply pulling out the end of the coil that feeds through the grommet so the feedthrough wire is in the center of the hole and not pressing up against the left side of the grommet and arcing through the rubber to ground that is millimeters away. The stench is the burnt grommet.
Good Luck.
