PLL Question
Crambone
Well-Known Member
I Support WorldwideDX.com!
Jan 22, 2019
563
175
53
57
If a Cobra 2000 GTL has a MB8719 would it work as a stock no channel mod radio?
Assuming it isn't modded for the extras. Or if so, it's put back to stock.
It was modded for extra channels but I took the mod out and I’m getting weird frequencies now.
this is the board that was removed.
Does it have an 11.325mhz crystal in X3 spot? Its to the right of the PLL and 4 lined up tuning cans towards the left front.
If for some reason X3 crystal was changed then it would be off
The board that was hooked to the mic line and has a relay, looks like a Roger Beep board.
  • @ Hambones amps:
