Power effecting SWR?
Kellin Cannatella
New Member
Jan 12, 2019
13
3
3
41
so I notice on my galaxy 98 with power knob at 9:00 position or less my SWR reads about a 1:1-1:2. If I turn it any higher SWR jumps straight to 1:4-1:5. Is this normal or should I be concerned? And would it TX better with less power and better SWR or higher power and slightly higher SWR?
I bought radio used so I don’t know exactly what’s been done. My local guy said it’s doing 300 on his bird meter but I didn’t see it with my own eyes so who knows. It seems to be doing ok. I’ve talked to guys 12-15 miles away without any problems
Depending on how the SWR bridge is set up in that radio, there might be a need for a minimum amount of power to read the SWR properly. It shouldn't really take much carrier to do so, though.
300 watts? Don't spend too much time looking to see it with your own eyes. :whistle: Also 12-15 miles is nothing. A legal 4 watt radio should do that.
I wouldn't buy into the 300 watts and if that's what a meter says without it being on an oscope then around 100 of that is harmonics (ghost watts). So it I have to agree on the harmonics playing a role in whacky swr readings. Not knocking the radio by any means as I'm a galaxy black box fan too despite some of the backlash that radio gets. Properly tuned it should do 200 +/- AM.
Reactions: 357magnum
the SWR meters in these radios are calibrated with the power control set to maximum.
those above who said that the meter will read differently when power is lowered are correct.
there is an internal trimmer resistor that gets set for an accurate 2 to 1 SWR reading with the radio connected to a 100 ohm dummy load.
so, if your radio was aligned properly, you should be reading the real SWR of your antenna with the RF power knob turned all the way up, and when you lower the power, the meter is out of calibration and will read lower.
either way, you are dealing with a 1.5 to 1 SWR ratio which to me, means that my antenna is working and has a definite dip to its frequency range. a good thing when it comes to antennas.
remember that a dummy load will read a perfect 1 to 1 SWR over the entire HF spectrum, but won't get your signal out of the room.
the idea when tuning your antenna should not be to do whatever it takes to achieve a perfect 1 to 1 ratio, it should be to 'dip' the antenna and set its lowest achievable SWR within the frequency range of your radio.
BTW the tech that told you that your radio was doing 300 watts should have told you that it needed to be adjusted in order to lower that output the right way.
that 300 watt reading is due to either coils being spread thereby fooling the wattmeter with harmonics and fundamental frequencies being added together (wattmeters are dumb and don't know any better) or the bias on all the mosfets has been set too high and they are not long for this world.
LC
