if the radio is a grant export pc999 board then vr11 is the driver bias preset which is something you don't want to be messing with. if it is a pc999 grant export then vr13 is am carrier power preset.
doing it loose cannons way isn't the best way to do it but its the way most people do it,the reason its not the best is if you remove the am carrier preset and replace it with a potentiometer you have nothing to stop the carrier going beyond the stage of harmonics and premature meltdown of the dual 2sc1969 rf final transistors,not a wise move as they are exceptionally difficult to source now and becoming very pricey.
nearly every export radio i've ever seen with it modded that way ends up with burnt out rf final transistor/s.with all due respect too loose cannon its a suicidal way of doing it,and i mean no offense by that loose cannon as most people read how to do it off the net.please don't take it the wrong way.
the best method is to copy the way ranger rci do it on the ept 3600 chassis with variable rf power,i'll explain why after i tell you how its done.as that particular part of he circuit is very similar in all export chassis that clone the pb010 uniden board.
you would take a wire from the vr13 wiper end of r279 (5.6k) or from the wiper of vr 13 itself,run it via the wiper of a 20k potentiometer added to the radio and out one of the sides,(if the pot works in reverse change the side) then through a 3k variable resistor or a fixed resistor too circuit ground. the reason this way is better is that with vr13 still on the board you can set maximum power within the linear region of the final transistor/s,and minimise harmonics/burnout,the 3k or fixed resistor sets the minimum power level and the 20k pot allows adjustment between the min/max preset levels,ensuring you can't go above the linear region.
ssb power is already variable by using the mike gain control as in all ssb radios with variable mike gain.
all the chassis below use this method,as do all ranger chassis with variable power with ept3600 boards,the only thing that changes is the value of the added potentiometer and the variable range setting preset,the circuits are all identical,i would imaging the best value would be for whatever range you want the variable power to cover.trial and error will find the best arrangement for you.
http://www.cbtricks.com/radios/galaxy/dx11b/graphics/dx11b_sch.pdf
http://www.cbtricks.com/radios/galaxy_other/ssb_base/graphics/galaxy_ssb_sch.pdf
http://www.cbtricks.com/radios/galaxy/dx44v/graphics/dx44v_sch_main.pdf
