President HR2510
Crambone
I Support WorldwideDX.com!
Jan 22, 2019
563
175
53
58
anyone know the number or type for D152? The dummy diode? I can’t read it off the online schematic or the old diode.
Uh, "dummy diode"?
That's the reverse-polarity protection diode.
Good name for it, though.
Any power-supply rectifier will work. The bigger the better. The voltage rating of the part won't matter. We adopted the habit of using a 6-Amp rectifier diode in all the mobile radios we service. It gets upgraded, if the factory didn't install one that size.
Tends to prevent trouble down the line. The original 1-Amp diode shown in the schematic is prone to explode and take itself out of the circuit if you hook it up backwards without a fuse. The bigger one won't generally do that.
Ok thank you, ya I was pulling it out to test it and I don’t know if I broke it or it was broken. No modulation and only the bar meter is working on the screen.
Yes it receives only other thing besides part of display not working is the frequency knob. Channel buttons on front panel and microphone do work.
Check the F Lock button.
I should have stated i tried to remedy this problem by recapping entire radio and removing all glue. (Glue remover was not fun).
I will check the F Lock button .
ok I replaced the diode and some of screen is lit but not all. I don't show any voltage on D112 or D113
Update we now have modulation it was a bad mike element but still no METER bars showing but everything else working. any thoughts on were to look?
