President madison issues
Staybolt
Sr. Member
Mar 20, 2013
1,098
458
113
My old 858 madison has an issue on ssb that it will not transmit on usb but it does on am and lsb. Anyone got any ideas why?
Also, make sure all of the crystals are properly seated and the sockets are in good condition. That can also cause the issue you're describing. It is also possible that one of the USB crystals may have gone fault. It can either be the the 11.2858 crystal, or the 7.8025 crystal.
~Cheers~
Can't remember if the 7.8 MHz carrier crystals in that radio are in sockets, or soldered in place.
If they are in sockets, you can swap one for the other. If a bad USB carrier crystal is the culprit, this would make USB only appear to work, and AM/LSB would go dead.
Every other way I can think to check will call for one or another piece of test equipment.
