President Richard II Tech Menu Values Saving But Not Applying
DTB Radio
Sep 14, 2005
1,101
205
Carlisle, PA. USA
www.dtbradio.com
Loving the new Richard II for the most part, but while changed values in the tech menu seem to be saving (and seem to be having the desired effect while in the menu, as in modulation level increasing), after the radio is powered down and powered back up, the effect is not applied in normal operational mode. The value, however, is still saved in the tech menu, and while in that menu, the value effects are seen. Am I missing a step here? Never had this issue with other President models, or other make/models with a similar menu.
  • @ Hambones amps:
  • @ ShadowDelaware:
    Hambones the entire amp section would have to be retuned, and the rf transformers re wrapped.
