Pride TF 1000 Frequency counter Help.
Techno1
244
71
38
49
New Hampshire
So I found another Pride 1000 freq counter counter works great and having problems with the clock.
The one I have from day one when it powers up the clock starts at zero and starts counting as I dont keep it plugged in all the time and I kinda like that so when it starts i know how long I spent in my shop.
The one I just picked up is in great physical condition but the clock boots up to 11:11:03 then starts working as a clock.
All buttons on the back work Hold/Fast/slow the 24 hour button works.
I cant set the clock back to o:o:o when I push the set buttons always goes to 12:?:? and can set any where but 0:0:0 and again when I power off and power back on it starts at 11:11:03.
I have a parts one and i changed out the cd4016 chips and still the same problem also changed out the clock chip and same problem.
Would anyone know of this problem and a fix so the counter when powered up will start at 0:0:0 like a timer.
ill post the schematic/owners manual here
thanks
Changing the electrolytic caps may or may not help. But they are too old to be trustworthy. The're easier to find than a new MM5314 clock chip.
Thanks nomadradio I will do the caps first there are only 4 of them. Might have to order if I dont have a replacement value.
Nomadradio I was reading some post and all say to replace the caps since they are so sensitive in this clock circuit should I get the same values or can they be a bit higher in value?
Here is an update on the pride counter.
I replaced all the electrolytic caps (3) and still when powered on it starts at 11:10:03 and works as a clock. the counter part work good just the clock is suppose to start at 0:0:0: and start counting as my good one does from day 1.
I do have a good one and when I get time I will open up and start swapping parts since all chips are in sockets.
I do have a parts one and changed out the clock chips and the 4016 chips and have the same results.
This clock chip does not have a rest pin.
And suggestions or where to try next?
thanks
Well like I mentioned I do have a good 1000 when I get a chance I will open up and swap out the chip and see if its the clock chip. The spare one I have was a basket case and I never had it working so that chip i swapped might be also bad
