I have an AL-80B in which the 3-500Z tube will not light up. HV is showing just under 4000.
It worked fine the last time I used it and there was no noise or smoke when I turned it on today.
I reseated the tube in its socket with no improvement. Is the problem likely the tube itself ?
I hesitate installing a new one only to have it burn out due to another issue with the amp.
Thanks!
Thanks!
