I recently got a used Realistic DX-160 and love it so far, however there is a problem I am having on Band C. I am not sure if the problem existed when I first got the radio since I have been doing most of my listening on Band D.
The other night I noticed when tuning through Band C that I was getting no signal at all, and the AF Gain had to be turned up considerably to hear static. I thought maybe it had something to do with my antenna or just a bad night for listening so I would wait until another time to try again before worrying. In the morning I got up and decided to check Band C in the morning. When I started up the radio, it was working fine on Band C. I tuned into a station low on the meter an sat back and listened for a bit. However after about 2 minutes of listening, suddenly the signal was gone in a flash. The gain had to be turned up again to hear static and without adjusting the tuner, and the AF gain at full, there was no signal at all.
I turned the radio off and waited another day to see if it would work again on its own but after 24 hours, it is still not working. All other bands work excellent with no signs of problems. I stopped using the radio since in case so not to damage the unit.
Taking the upper and lower covers off and doing a visual inspection, I see no problems. I do have the service manual on PDF, but don't know where I should start. Any help would be greatly appreciated.
