problem with palomar 300a
tallsup
May 20, 2008
29
having a problem with my 300a,they say it sounds real fuzzy and crackly
any buddy have any thoughts or have this problem
I would check the HV capacitors first. They are pretty cheap and simple to replace.
Sent from my iPhone using Tapatalk.
45, North Florida
Good point too trucker. When the hv caps are weak, you will sound sort of like you're talking through a fan. Ask others on the air if this is what they are hearing.
45, North Florida
I have a friend that had the same issue with his 300 recently. The new electrolytics solved the problem
45, North Florida
palomar
I will put 2 new ones in it,when i was just on the air a guy said it was real fuzzy sounding and a bit of a hum
Even if that is not the main problem they still need replacing after all those years.
45, North Florida
They should be 100uf 450 volt caps if I'm not mistaking. Don't forget to make sure you short them out before you touch anything. The high voltage inside these amps CAN KILL you. Keep us posted.
45, North Florida
I'm glad to hear that you got it going again. The caps are a simple and cheap fix to restore the REAL tube sound that should be coming from all these old tubers. '73!
45, North Florida
