Good point too trucker. When the hv caps are weak, you will sound sort of like you're talking through a fan. Ask others on the air if this is what they are hearing.
They should be 100uf 450 volt caps if I'm not mistaking. Don't forget to make sure you short them out before you touch anything. The high voltage inside these amps CAN KILL you. Keep us posted.
I'm glad to hear that you got it going again. The caps are a simple and cheap fix to restore the REAL tube sound that should be coming from all these old tubers. '73!
