Pyramid power supply issue
CbRadiosPRONTO
Well-Known Member
I Support WorldwideDX.com!
Mar 21, 2014
432
166
USA
www.cradiospronto.com
ps36kx going into protection mode when turned on. +/- short. Protection diode is ok but it appears there is a short to ground with a transistor. I cannot find anything in this transistor on the net.
TYN416
GKDXW U
MAR 138
See pic
I would suspect one or more of the 2N3772 Pass Transistors has shorted. Very common in these.
Order me up a few extras for my PS26KX while your at it :cry: You would think there would be a beefier replacement part. It's down currently and I use it for powering cooling fans because it's variable down to 6 volts.
The part you showed looks like a voltage regulator? If so this one is a TIP41C
The Pass transistors are on the back heat sink:
Thanks for the response. I closed for about 10 days and I'm just getting caught up. Every time I try and help a local guy on something different than a radio, always ends up being s pain.
Here is a pic of the board. I don't think it's the regulator you're referring to.
By the way, I couldn't find this post so I posted it again. I noticed you responded in the other section. I will go ahead and use the other post as somebody else also responded. I can probably delete this one. I'm not that proficient with this forum ever since the update and dropping the tapatalk at.
