Qrp RadioFun
I know this post has been slow for a bit but I thought while I had a moment I would add some input.
I was a "Life is to short for Qrp" thinker for many years. The legal limit seemed almost Qrp at times.
Then for some strange reason 7 or 8 maybe more years ago I thought about getting back into CW...Why? Who knows just thought since I went to trouble to learn it 3 or 4 times I might as well use it.
The quest started when I wanted to operate Old Rig Night during the Christmas Holidays while on vacation from work. I then looked around and found other than a few SSB or AMer's groups on just 3 or 4 frequencies on 40 and 80 meters most of the activity during the couple of days everyone operated CW with the old rigs.
So what to do? Well I had forgotten about my old Johnson Adventurer covered up out in the barn for 10 or 15 years (maybe more). Would it still work after all this time?
I brought the old girl in the shop and cleaned her up and it really looked pretty good inside considering. I noticed one B+ cap was leaking, so I dug in the parts bins and found one and changed it out. Do I dare fire the old girl up...what the... Why not!
I plugged it in and turned on the switch with a broom handle from a couple feet away...WOW no Bang...no magic smoke either!
Where in the H... did I put that old straight key? Found it...do I dare...OK where's the dummy load...OK got it, and also old power meter from RS.
The time was upon me, a quick key down just to see if it would work...Nothing! OH H... no crystal damit! OK where did I put those? Found them in a old jar buried up on the self...OK 7122 kc should work(had that since my old Novice Days)
Crystal installed...key down again?...Going for it...WOW 17 Watts and still no smoke...Lets tweak the controls...WOW 32 Watts no smoke!
Well a little more tweaking told me I really needed to load the old girl up about 20 Watts to make it sound like a CW rig should sound and not like an old Browning Ping!
Wow I'm getting long winded here! I operated that weekend and made about 10 or 15 contacts in the old Novice bands on 40 meters at a VERY SLOW, mistake ridden pace. I had to learn how to send my own call again!
This with only 20 watts and a Double Zepp up about 15ft. I received good reports even with a little crystal drift after I would start sending...I was hooked!
The thing I did not expect was most of the operators were running Home brew transmitters at 5 watts or less...single tube oscillators or the like and we could carry on quite well...damn amazing stuff...Go Figure!
Well to bring this to some kind of ending. I bought a $29.95 20m transmitter kit at a Ham fest and built it up. The kit was Crystal controlled and run 2 watts maybe just a pinch more.
I worked 35 or 40 states and some to Canada over the next month or so. I was in a Qrp weekend sprint and the final blow out...bummer! No output on the wattmeter except a little, maybe 200 Milli Watts...wait a minute someone's calling me!...No way they
will never hear me! I called back!...Holy S.... they can copy me!
I made 21 more contacts in the next 2 hours...and can you believe this...one of them was in Honalulu,Hi...I have the card to prove that one! I begged for it!
I see I am burning this post to the ground. I can carry on, and I could continue with more useless info...but 3 or 4 kits later, couple of which are transceivers with VFO control and my CW much better. I am still enjoying Qrp.
Enough Here
All the Best
BJ
