Ranger RCI 69 base
captbrandon
New Member
Dec 11, 2023
I have a rci 69 base and my signal meter is EXTREMELY tight. Almost nobody gets me over 7db and the strongest stations under the best conditions might hit 9.
Anybody know how to adjust the meter?
Simple adjustment should take care of the issue, but occasionally you will run into drivers with the actual meter drive circuit (failed diode or capacitor, out-of-spec part value, etc). You can often give the meter a bit more room for upwards movement by using a bit larger filter cap in the meter drive voltage path. This holds the voltage high for just a bit longer, allowing the meter to move higher before the drive voltage drops.
Anybody got the information on tuning out the wattage on a Ranger RCI 69 base.? I bought this thing Used from a one owner and he said the only person that it touched. It was the guy to CB shot. This thing is so far out of whack on a.m. SSB lower and upper side man up into 10 and 12 MHz. It’s pitiful, but I’m just more or less worried about my a.m. inside band stuff.
