Ranger tr-696 mod explanation pls
Robert Foster
Jan 10, 2017
22
10
13
61
Opened up RCI tr-696 F1 and found toggle switch connected to jp10 the R.B 8vdc that it just two wires switch directly to board. I know that this connection leads to all of the components that make roger beep work but no roger beep on this rig.Can some explain what that is for, the has been channels added?? Thanks
There is a Superstar radio that uses a big switch inside for the 11m modification. Some of the Superstar radios also had a Roger beep that could not be turned off. There is a mod to clip something to keep it from beeping. Are there any numbers on the board?
