RCA CO-PILOT 14T304 help and alignment info
KD2GOE
May 30, 2013
952
220
173
45
Buffalo
Guy gave me a RCA CO-PILOT 14T304 it works but I had to rewire the mic plug to the standard Cobra 4 pin
it took me a min but some one did upper Channels on the ANL switch and I am going to reverse it to normal as I see it having no point at every one is using SSB up there
ok but I am getting 4 watts from Ch11-40 and 0 watts on ch 1-10 I am picking up some contact cleaner tomorrow at work to spray if that don't work where can I start looking to fix this?
and where can I fined alignment info?
I had it on the freq counter and I am getting NO TX Freq read out from Ch 1-10
I hope the PLL is not busted {Cry_river}
if the vco is not locking on in the lower channels this will happen. just look at the manual and check the internal adjustments to see if some there is out just a little. will lead you to what might be wrong also.
ok thanks ill take a look..
