hi guys got a 2950 an when i talk skip people say im off freq whats the best way to fix this problem an i live to far from a radio shup to send to thanks in advance
If you have someone local who has equipment that is ON frequency and you are fairly sure of this you can easily make adjustments inside the radio to re-align it. While you lack the proper equipment to correctly do an alignment it is possible to do it by ear and it will be "good enough" for most purposes.
Go to cbtricks.com and look up your radio in the information section. Do you have the DX or non-dx version? Look up the alignment instructions and you'll find the adjustment point for LSB (L29 on the old model and L19 on the dx). Then you'll need a non-conductive tuning tool or plastic screwdriver to make the adjustment.
You'll center your clarifier and then have the other station count to 20. As they count you can adjust the tuning location inside the radio until their voice sounds normal.
Fairly simple...not exact but it's possible to do.
Next best thing is to buy a nice 8 digit frequency counter with probes and then you can hook right into the radio and adjust yourself without the other party.
I have aligned 4 of my 2950dx models like cbradiomagazine.com point out - and it's works just fine that way.If you have someone local who has equipment that is ON frequency and you are fairly sure of this you can easily make adjustments inside the radio to re-align it. While you lack the proper equipment to correctly do an alignment it is possible to do it by ear and it will be "good enough" for most purposes.
just a question when doing this do you also use the vr listed as freq adjust.
im unsure of the vr number without looking it up . bu i think with radio
upside down facing you believe its on the left hand side towards
the front. i thought you tuned that vr but wasnt sure. why im asking
That's a reason of resurrecting 16yo thread?I have good frequency counters and aligning by ear works great quick and easy
It's only funny 'cause it's true.
