Hi guys, Could use some pointers. Rig uses 4 pills, likely 2290 equivalents. Examined RF Deck. Heated rig up with 50W keydown. All 4 pills heating up about the same checked with infrared thermometer.
Normal: AM will key 150W swing to 400. SSB/400 (did not run wide open ever - usually key at 80 or 100 to talk)
Now: AM to 110W swing to 175. SSB 110W
What might be the problem? I am not a tech but do have some electronics skills. Can solder well and have an excellent VOM. Please throw me lots of details and pointers that might assist me in the diagnosis and repair if you would. A knowledgeable local has suggested the AM Regulator may have partially failed?
Thanks for any help !!
