RCI 2995DX voltage regulator upgrade?
Crambone
I Support WorldwideDX.com!
Jan 22, 2019
563
175
53
58
Anyone know what the TOSHIBA part number is for the Upgrade Voltage Regulator?
2SA1302. 15 Amp, 150 Watt rating. More to the point, it has a larger surface area in contact with the heat sink. That alone means the part's temperature will rise less per Watt of heat than the smaller physical packages can allow. Temperature rise is all about the thermal resistance between the part and heat sink. Bigger contact area means lower thermal resistance in degrees temp rise per Watt.
