removing heat sink compound?
GnG8d
Well-Known Member
Jun 28, 2010
2,037
355
93
Ohio
I'm sure that this is not too difficult, but are there any recommended quicker/cleaner methods of removing the heat sink compound from a radio? It looks like they just slather this stuff on with a paint brush, but while I have this 2970 apart I am replacing all of the compound with more "precisely" placed Arctic Silver 5.
I'm guessing acetone or mineral spirits and a non/low lint cloth of some sort. It's some pretty tuff stuff to even wash off of your finger, and I'd rather not just push it around trying to remove it.
Dabbing it off with a dry cloth will do it. That compound stuff will get on everything! Pretty messy.
I clean the compound off the back of CB radios with alcohol. Then I run a piece of dry cloth on it and look for any spots where there may be a fiber residue. Sometimes there are metal burrs that will catch the cloth fiber, and this is a potential trouble spot. De-burring it carefully will ensure that the device insulators aren't going to be compromised by a burr sticking up. It will also insure a flat surface so that heat transfer is what it should be.
Using lapping compound on all contact surfaces might help too . . .
Isopropyl Alcohol has worked well for me in the past. 70% will work, but if you have 91% use that.
