roadcom cb
sa143
Feb 9, 2008
3
2
11
i the happy owner of 2 pcs team roadcom
THUNDERPOLE - Team RoadCOM C.B. Radio
However, I have strange problem with both of modolation on fm (devi) is
very low have to measure and trimmer set rv-4 that runs
fluctuated up but it helped only slightly, there are some who have info about it can be
be a component fault? or a good idea and of course have tried to switch
mike same dirt.
has contacted team, they were not helpful
kenneth sa143 Denmark :crying:
Deviation Flatulation
If you're sure that RV4 is the FM Deviation potentiometer, AND that you are turning it in the proper direction, I'm not sure if there's much more you can do. The old Cybernet rigs generally sounded like azz on FM, but this is not one of those. Perhaps there is a design fault in the rigs...
