Robyn SB-520
Holydvr
Tony (The Flasher) 1776 NW Arizona
Nov 2, 2018
587
615
103
47
Golden Valley, AZ
When I received this radio, it would turn on and it had no receive. It would click over to tx but had no power out. I replaced the driver and final as well as the AM regulator. The way someone had put it back together had most of them shorted with no screw insulator. Tx now seems to work fine on AM and SSB with good power out.
I plan on recapping the entire radio if I can get one final issue sorted.. SSB has great receive sensitivity as well as volume when the volume control is turned up. AM sensitivity and volume are horrible. The volume control has to be turned all the way up to even have a chance at hearing anything even a local is saying. Have to be fairly close to the speaker to hear it also. Anyone run into this before? I will continue to troubleshoot as I can, but figured I would see if by chance someone has seen this in this 858 chassis before.
My guess would be a bad cap somewhere in the audio chain. Since you're already planning on recapping anyway, it wouldn't hurt to move forward with that and see if it fixes the problem.
Reactions: Holydvr
My first question would be what does the S-meter do? Does it fall off for AM and read normally for SSB?
Or does it show mostly the same on AM or sideband?
If it does, a bad electrolytic cap in the audio is where I would look first. Following the AM receive audio with a 'scope down the audio path would reveal the culprit. And if you don't have a 'scope handy, just changing all those aluminum electrolytics would probably fix an audio fault.
Probably.
Just make sure they ALL get turned around the right way.
    Scheduled for Jul 4, 2026 Saturday Live Streams:
    To celebrate the 250th birthday of our great nation. We are giving away not just one, but multiple antennas! The Grand prize is the CaHR-Tenna Hydra Antenna, along with several other antenna prizes that will be announced throughout the giveaway. Whether you're a new ham, portable operator, POTA activator, or an experienced HF operator, this is your chance to upgrade your station. Prizes Include: HRA Hydra Antenna (Grand Prize) Additional antennas from HRA More prizes may be added during the giveaway!
    CQ Worldwide VHF SSB/CW Contest: 1400Z, Jul 4 to 1400Z, Jul 5
