A Winner has been selected for the 2025 Radioddity Cyber Monday giveaway! Click Here to see who won!
Has any one ever put one in side a mic i have a hr2600 with a desk mic and want a beep but don't want it in the radio i have room in the mic to put it just need to know if it can be done ???
That is cheap i was just asking because i like the desk mic that i have now and have the roger beep board so i was looking to see if it could be done..
I don't know what brand roger beep you have, but most I have seen have 5 wires:
Power
Ground
Audio
Transmit x2
Power & Ground are obvious. Solder the Audio wire of the RB to the Audio wire of the mic cord inside the mic base. The TX portion of the RB goes in series - remove the TX wire inside the mic and solder to one of the TX wires of the RB (refer to instructions for proper wire) then solder the other TX wire of the RB to where you removed the original TX wire. You'll probably go through batteries quickly with the added draw, so you may want to consider adapting a wall wart instead. If you wanted to add an on/off switch place it in series with the Audio wire on the RB module.
thanks i do have a 5 wire and i will try it that way i might try it tonight every one has been telling me it can't be done and i don't see way not your going to tap into the same wire's in side the radio except for the power i think it takes 8.5 but i could be wrong so thanks for the help again ...........REV
