Roof mount on a 2017 f 150
undertaker
Undertaker
I Support WorldwideDX.com!
Apr 5, 2006
3,191
3,454
273
68
Texas
Can I mount a Wilson 1000 roof mount on my truck?
The body is aluminum.................... plus the roof has ridges in it damnit!!!
Reactions: 357magnum
I just put a Stryker SRA 10 mag mount on the roof of my Explorer it's there but same problem ribs won't let me get it in the center so it's way back on the roof but works fine . Your Cab and nose of truck are steel correct ?
It should still work ok ! Being an F150 it still should have enough steel too reflect , I never thought of this my wife has a new F150 Lariat ! I never tried to put a radio in in yet . She hates it (Radio) ! Loves the truck !
What's wrong with aluminum? So long as the roof isn't plastic or fiberglass, aluminum should work just fine. You can't use a mag mount on aluminum - of course - so a solid mount will be have to be used in its place. But it should work just fine.
Think about it for a sec; most base antennas are made of aluminum.
Have a local friend that has his antenna mounted on his fiberglass truck shell on a Ford truck. He added aluminum strips lengthwise along the inner shell and he made that work just fine. Had to add a bunch; but it works.
Have to get out the drill since the mag mount is out. I tried looking up the roof of a 17 f150. Looks like you have some space between where the ridges end and the back of the roof. Might be able to pull out the 3rd break light and access the underside of the rear roof without dropping the headliner.. Or you could drop the headliner and put your hole in the middle the roof a little off center. Or look at a bed rail/steak mount...
Totally agree Robb...Aluminum is listed as one of the top five conductors of electricity. Steel on the other hand with all its impurity factors, never made any conductivity list, too many types or variables. Aluminum with its high resistance to corrosion has been the perfect choice for the communication industry for years. I wish my roof was aluminum!
Nothing wrong with steel either. I like my steel roof because I can use mag mounts - and do. The only difference between steels would be the velocity factor; which is no big thing. Same goes for aluminum. Velocity factor isn't exactly the same between different types of aluminum either; but it will still work. Velocity factor is a concern when building an antenna from scratch, or defining the length of a 1/2w cable at a given freq for the most part.
Would I still get a good
swr being that far back?
I dislike rust and try to avoid mag mounts whenever possible. The Velocity factor difference between the two different metals in this case will have a minuscule effect. Capacitance variations between the base of a mag mount and the body is more concerning. I’ll take a body made of aluminum over steel any day. The same goes for the truck bed. If I plan on dropping tool boxes or concrete blocks on it, I’ll buy a good bed liner. Sorry Chevy, Ford won that argument hands down. This is my opinion of course.
One thing to think about is the strength of the aluminum vs the steel. I would reinforce the roof mount to be safe. As I remember, there were issues with the aluminum bodies getting torn going thru a car wash because of the am fm radio antenna. Just a thought
Reactions: Robb
Undertaker The Stryker Mag Mount I put on my Explorer back by the hatch because of those ribs my SWR is perfect ! It surprised me for sure took in out of the box dropped the whip in and it was a done deal !I guess is just got lucky first shot !lol
