S.O.S. Electronics Scout 20 Amplifier help
Aug 31, 2020
48
20
18
66
I'm looking for the value of the RF choke on the upper deck. I took a pic of the part from another amp but need to replace the one in a different Scout 20 that burnt up. I searched everywhere and could not find a schematic.
It looks like a non-ferrite support, so chances are an air would coil calc would get you reasonably close. Why not just wind one with the same number of turns on the same diameter form with the same diameter wire?
Reactions: tecnicoloco
Because I don't have the materials. Looking for the mH value to purchase a new one. Thanks.
Is that choke part of a feedback circuit?
No.
It's the plate choke, or "anode choke" for purists. It does two things. Provides a low-resistance path for DC current from the HV power supply to the tubes' plate circuit. Second, it blocks the flow of RF current that would otherwise feed back into the HV power supply.
Reactions: Alabama Trainman
If it's a simple plate choke for a cb amp it easily home brewed. See if you can borrow an inductance meter
Z-28 ohmite chokes are readily available. It would be easier to just replace it. If it was a part that was unobtainable, then I would fabricate my own. Thank you all for your input. The actual value is now known for me to carry on. 73's
Reactions: linearone
