sb754 swap
J
JustinDePolis2
Guest
Just a question why did you change it... remember that the default application is a current regulator, NOT a voltage regulator.
Click Here To Go To FG Best Communications
</p>
I swapped my sb754 with an upgraded transistor and it doesn't get hot now but i notice a backwards swing with the amps on. Do i have to change the driver for the modulation transistor as well. What gives?
Yaesu 101b</p>
