I have a Uniden BC350C scanner in my semi and it won't pick up squat any more. For example if I push to hear CB I have to be really close to pick anything up. I was using an old cb antenna which I thought worked as good as any antenna I had tried. I have tried switching antennas and including one that came with the scanner (it used to work). Any ideas as to what might be the problem.Thanks.
