Here are the adjustments for this.
AMC-Q302,R312
ALC-RT-402
AMpwr-RT101
TXtune-T401,T402,T403,T406,T407,T408
To turn the clarifier into a slider you cut the black wire on the control and solder it to ground,Then cut the green wire and solder it to pin 3 of IC 601(+8 volts),R303 and 304 cut and R302 jumpered.
I dont know of any easy way to get xtra channels with this radio but someone out there might.
Hope this helps!
</p>
