Sears Roadtalker
fasteddy
373
2
26
If you would post the model number I can get you the info you seek.
fasteddy<img src=http://www.ezboard.com/intl/aenglish/images/emoticons/smile.gif ALT=":)">
</p>
You're welcome. Just remember, don't turn your AM or SSB power all the way up. It is much better to have a lower dead-key with a lot of swing than to have a large dead key and little swing.
Have fun!
</p>
Reactions: Groundhog KSS-2012
934.38260700 how about that one? would be hugely appreciated...
any chance of putting extra channels in these?
<img src=http://www.chargerscastle.com/users/kypoohsig.gif>
Poohbear
618 in the BlueGrass State</p>
Here are the adjustments for this.
AMC-Q302,R312
ALC-RT-402
AMpwr-RT101
TXtune-T401,T402,T403,T406,T407,T408
To turn the clarifier into a slider you cut the black wire on the control and solder it to ground,Then cut the green wire and solder it to pin 3 of IC 601(+8 volts),R303 and 304 cut and R302 jumpered.
I dont know of any easy way to get xtra channels with this radio but someone out there might.
Hope this helps!
</p>
Thanks! Mucho Appreciated.. Wish their was a easy way to put in Extra channels thou! Ah Well
Thanks!
ScottF
Poohbear
I need pot numbers for am power, mod, and ssb power. Can't seem to find them anywhere. Thanks
</p>
