service menu: increase output power ssb CRT 7900v turbo
Emir999
May 18, 2025
3
60
Can someone tell me which parameters of the service menu I should change to increase the output power in ssb of my CRT 7900v turbo?
I would need the correct values to enter.
Thanks
menù di servizio: aumento potenza di uscita ssb CRT 7900v turbo
Qualcuno mi saprebbe indicare quali parametri del menù di servizio dovrei modificare per aumentare la potenza di uscita in ssb del mio CRT 7900v turbo?
Miservirebbero i valori corretti da immettere.
Grazie
I know which parameter to adjust as I did it on mine. I'm not going to give that info out here though because..........
1) You risk bricking the radio messing with the service menu, and
2) You can only get about another 10 or 15 watts out at most, so it is not worth the time to do it.
If you really want to go ahead the info is out there in the wild on the internet.....that's where I found out how to do it. YMMV.
Reactions: Brother DXer
