Homer, I model using Average Earth, unless I have a specific reason to change the ground description. My area is in the 15 zone, I just got that wrong long ago on the ARRL chart that is not so clear.
I'm not sure, but maybe we have a difference of opinion, based how this issue works. I've posted this idea to try and explain my thinking on this before and I can't go into all the aspects involved in this issue. So, maybe I did not describe my idea well or it is just too complicated to get clear, without others being there when modeling. After I learned to model with Eznec, is when I changed my thinking on this. I use to think I was in the 30 zone.
However again, since I was able to model I have determined my idea about how this all affects an antenna was exactly backwards from my earlier thinking. I know I'm in trouble again for changing my mind about this stuff.
I've said from the beginning, "...I don't sense much difference in my antennas...even when I mount them on the same pole and wasn't comparing antennas. So, since I was saying sameO sameO story about my antenna results, and they all seemed to work well...I figured the best performance might just prevailed in areas like mine and similar areas all around. I also had the thought...maybe that was why I don't see differences in signals like others report.
I never figured it was about my radio having 6db/Sunit or anything else either. I also figure if an antenna was in an area with poor soil conditions...it would perform poorly, and maybe then you could detect differences more easily for some reason that I did not understand. There is more to all this obviously, and in part it has to do with and ideas about having good working radials, vs. poor, or no radials, or so I believe, just
Bob and I have discussed these ideas way back, and maybe I just misunderstood what he was getting at...or we both have changed our minds on this subject,
again, or it was just me.
My models show poor soil looks to improves the gain and effects the pattern and angle a bit too, but I'm not sure about direction of angle...it may look to go lower.
Very good soil (higher numbers) typically show the gain drops as the soil gets better on this scale.
I tend to see my models also show a drop in gain, as I improve the accuracy of the models...so I think I'm understanding this pretty close. Understand though, in my book...nothing in this antenna business we talk about ever looks to me to ever be 100%.
The short story is, if I want to show a model with a better gain, then I can set the model with poor or worse poor soil conditions. If I don't indicate this...then who knows. Then the gain and pattern look improved and show more gain. I subtly demonstrated this idea recently in my J-Pole thread, and that is how I got those models of my J-Pole to show remarkably more gain as you will note.
Also note that
physically being over sea water like in a boat or on a ferry...improves my mobile range remarkably in my experience. High bridges also over water and high up as a similar effect, although I think that might be mostly height...and that should prove something of the idea about height that I try to describe with the S4 advantage.
I also note that from Galveston Island, I find it difficult to impossible to contact 60+ miles base to base, or base mobile for sure. But there are hot spots on the Island that are just like being on sea water...and that is pretty remarkable too, and it is repeatable from such spots most of the time too. I will describe these areas as being really close to inland water like a low bridge or as sea water cut or bay that we can get close up to.
Another thing about a model set over sea water is as the height increases the gain decreases, so better reflection might be working in that good number area.
I'll post a model or two, and we'll see, OK?
Eddie.
