sirio antenna
Al n3izr
Apr 28, 2013
53
11
18
69
Hello anyone got some info on ten meter change over for the sirio antenna.
I am planning to use one and was going to use the same settings as
the cushcraft ten-3 like to hear what others may have done with this.
Al N3IZR
Recently did my 4 element siro.Best just to scale it up. Element length is also dependent on spacing , element and boom diameter,and how the elements are mounted and driven. Unless you can copy all that it's safer just to scale.Try one of the modeling programs ( I use yagi cad, it's free and it works)it will show you if those setting work. Multiply length and spacings x .96 will get you ball park ,and you may have to adjust the gamma match
I modelled the spacings and there was very little difference between the stock and modified.
