Sirio Performer 5000 whip
2NC995
DAN
Feb 23, 2008
2,219
4,005
273
Coastal NC
I am needing a long whip for an antenna project and the Sirio replacement whip may fit the bill.
Does anyone happen to know, or even an approximation is welcome, the diameter at the heavy end?
I’m looking for something like a Wilson or Predator whip (thin and light), but having never seen one in person I suspect the Siro might be substantially heavier.
Most of those stainless steel whips taper from 3mm on the bottom to 1.5mm on the top
Ok...was thinking about an 8th, which is close to 3mm. Just need to make sure the Sirio isn’t too much bigger than that. I can make the hole bigger easy enough, but I want a slender/ soft whip
    Tucker442 has left the room.
    LIVE 10:00 AM EST :cool:
  • @ Charles Edwards:
