Sirio Tornado
I put it up myself but my pole was already up. I just lowered top section down to remove the Antron and add the sirio. For tuning swr I just set the sirio over the top of the pole to test after adjustment. Use blue loctite on all screws and set screws.
Was the hardware good enough or did you use self tapping screws?
It's very simple to build. Just got to get swr set right with the top section. I had the Antron 99 and the TX and RX is better with the sirio. Get your measurements all correct and all the same for the 4 radials.
How much of an improvement over Antron 99
Undertaker, you measure the top whip, (stinger), to the desired set freq as in the sirio manual. The top whip should be measured as shown in the illustration in the manual. You want approx. 1030mm or 40.55" for center of the CB band or near it. Either that or use the length got 27.185 Ch19 @ 1060mm or 41.73" and go from there. May take some fine tuning, but there numbers should get you close.
Reactions: Galaxy 959
Bobby, did you get a chance to measure the dimensions I requested?
I'm looking forward to your report also.
Eddie this is what I have so far.. overall length of pre-installed base section..19/3/8 ths.
short base mounting element. to bottom of hub.. 9 7/8 ths. will get more info asap going to take my CHL class today!!
What I'd like to know is the length of just the radiator from tip of coil to top of radiator. Looks to be about 6"-8" of radiator & insulator up inside the coil, plus the 20" of base & hub should leave about 22'...?
Bobby just to be clear, here are images of the two dimensions I need the lengths of your Tornado 27. The second image (#0001.PDF) you can increase the size if needed.
Thanks for the mounting bracket dimension of 9.875" inches (9 7/8 ths).
  • IMG_0001.pdf
    IMG_0001.pdf
  • @ heartbreaker3473:
